External User Frame
sinan78
I have encountered a problem with S4C robot when i want make a moveable user coordinated system.( irb and positioner).
<?:namespace prefix = v ns = "urn:schemas-microsoft-com:vml" /> 60006:%s User frame
The work object %s contains a coordinated mechanical unit which has no defined user frame.
Check:
Check the mechanical unit component of the work object
Regards<?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Hi again
I have solved this problem
If there is anyone who have come across this problem before i can help.
Regards
- 363 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 32 AppStudio
