IRB CAM
Dear sirs,
Do we have RS power pack for generate path by Gcode?
Make robot work like mualtiple axis CNC.
Best Regards,
Meckabot ABB
Hei.
I think you should look at mecanicel cut power pac.
Best regards klaus
Best Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
OR look at ABB's ... info for Mecanicel cut power pac
Mechanical Cut Power Pac is an AddIn to RobotStudio 4 (for S4 robots). This PP contains functions to help the user generate a complex robot path in RS 4. The same functions will you find in the RS 5 basic functionality.
Mechanical Cut PP has no support for Gcode.
ABB Robotics0
- 5.4K RobotStudio
- 382 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 281 IRC5
- 48 OmniCore
- 3 RobotStudio AR Viewer
- 739 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
