RS Screen / Video Capture
Has any had trouble with the video record function inside of RS? I currently have version 5.09.2237.166 installed. I remember a few versions ago I did install a separate video capture file that was posted on here I believe.
When I click to record it displays "An Unknown Error Has Occured" in the output window. What am I missing?
Hi Dan,
What does it say if you double-click the error message in the output window?
Johannes Weiman
RobotStudio .NET exception dump
Base exception:
Not enough storage is available to complete this operation.at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRIn ternal(Int32 errorCode, IntPtr errorInfo)
at System.Runtime.InteropServices.Marshal.ThrowExceptionForHR(I nt32 errorCode)
at ABB.Internal.RobotStudio.API.APIHelper.ThrowApiExceptionIfBa dHr(Int32 hr)
at ABB.Robotics.RobotStudio.ScreenRecorder.Start(String filename, IntPtr hWnd)
at ABBInternal.GeneralCommands.ScreenRecorderGUI.docStart_Execu teCommand(Object sender, ExecuteCommandEventArgs e)
at ABB.Robotics.RobotStudio.Environment.CommandBarButton.RaiseE xecuteCommand()0 -
Sounds like you might be out of disk space? The video is captured to a file in your temp directory, which is normally on the c: drive.
Johannes Weiman
ABB Robotics0
- 336 IRC5
- 67 OmniCore
- 830 RAPID Programming
- 13 AppStudio
