RS License
neil
I'm having a problem with starting RS when not connected to the network. Everything works ok when connected to the network. The error message I get is:
"No valid application license (Error code 80040212).
Do you want to launch the License Key Request Wizard to obtain a valid license)"
Sounds similar to the problem posted previously on this forum.
http://forums.robotstudio.com/forum_posts.asp?T ID=1443&KW=robotstudio+license
However I am unable to run as administrator and I am using Windows XP OS.
Thanks in advance,
Neil
neil2007-12-13 11:15:53
Hi Neil.
Please send us your lservrc file, so we can check it. You will find it using this path: C:Program FilesCommon FilesABB Industrial ITRobotics ITLicensingAlso generate a new License Key Request Form from your computer and send back to us.
To; softwarefactory_support@se.abb.com
Thank you.
Tonje Sandberg
Service Training Coordinator
ABB AB / Robotics Products0
- 363 IRC5
- 79 OmniCore
- 853 RAPID Programming
- 30 AppStudio
