IRB 340 - axis reaching the limit
mayma
Hello everybody!!
I have an ABB picking objects (with different orientation) from a conveyor and placing them (always in the same position) in another conveyor. The problem is that the value of axis 4 is increasing to 360000 and gives an error of limit. Can be a problem of axis configuration? The instruction ConfL/off is used because of the conveyors.
Please help!!
Thank you in advance.
try using a indreset function for axis4 with the short & refnum=0 active0
Thank you!!
I'll try it!!
