EIO_CROSS and circular references...
Hello all,
I would like to be able to use the EIO_CROSS section of my EIO file in order to be able to make my outputs dependant on one variable.
What I'd like to achieve is something like:
OUTPUT_A = ((OUTPUT_A) AND (MOTORS_ON))
But I receive the error 71037.
The way I've written the dependency in the EIO.CFG is this one:
EIO_CROSS:
      -Res "BXdobC1EinaFlot" -Act1 "BXdobC1EinaFlot" -Oper1 "AND"
      -Act2 "BXdoRbMotorsON"
As always thank you in advance.
  • A  "res"  can't be it's one  "Act"<?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
     -Res "BXdobC1EinaFlot" < > -Act1 "BXdobC1EinaFlot"
    If you need to do circular construction then you can use virtual signals as a temporary storage.... I think it can work, a work around.
    OUTPUT_A = ((OUTPUT_B) AND (MOTORS_ON))
    INPUT_C = OUTPUT_A
    OUTPUT_B = INPUT_C
    vulpes_h2007-12-19 8:58:44
