Problems starting any controller
Justi installed robotstudio4 onto an IBM T61P laptop and cant seam to get any controller to start.
RS seems to hang and wont respond, when ending task, in task manager, a message stating that it was " waiting for a responce from me to continue"...
never seen this one before nor had this problem. Any idea?...
Many thanks
Simon Turner
I think the problem is with the T61p laptop.
The same RS4 CD was used to install product on other machines with no problems.
The problem was corrected by unchecking the read only attribute to the virtual controller directories and sub directories, strange how we didnt have to do this on other machines as they are still read only and working fine?
Many thanks
Simon T
I am having the same problem on a Dell Inspirion 9400 running Windows XP Pro SP3. I just installed RS 4.0 and registered the license. I can open the station and import a robot but the controller will not start. No other ABB software is installed. You said that you unchecked read only for the virtual controller directories. Where are the directories located?
Thank You.
Chad
