SetProgramPointer
Hello, i try to set the program pointer, but I got an exception:
Specified argument was out of the range of valid values. Parameter name: Specified Url is invalid
The code is exactly the same as the manual:
Dim allTasks As ABB.Robotics.Controllers.RapidDomain.Task() = MyController.Rapid.GetTasks()
Dim firstTask As ABB.Robotics.Controllers.RapidDomain.Task = allTasks(0)
firstTask.SetProgramPointer("TESTM", 9)
and
firstTask.SetProgramPointer("TESTM", "TestR")
BR
Oscar
Here there are also the full error description:
System.ArgumentOutOfRangeException was unhandled by user code
Message="Specified argument was out of the range of valid values. Parameter name: Specified Url is invalid"
ParamName="Specified Url is invalid"
Source="Dcl.Base"
StackTrace:
at ABB.Robotics.Dcl.ExceptionHelp.ReThrowException(String objStr, String method, Exception exception, String additionalinfo) at ABB.Robotics.Dcl.ExceptionHelp.GenerateException(String objStr, String method, Exception exception, String additionalinfo) at ABB.Robotics.Dcl.ExceptionHelp.GenerateException(Object obj, String method, Exception exception, String additionalinfo) at ABB.Robotics.Dcl.ExceptionHelp.GenerateException(Object obj, String method, Exception exception) at ABB.Robotics.Controllers.RapidDomain.Task.SetProgramPointer( String module, Int32 n) at TpsViewManualGuidance.TpsViewManualGuidance.Btn_StartABBProg ram_Click(Object sender, EventArgs e) at System.Windows.Forms.Control.OnClick(EventArgs e) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ContainerControl.WndProc(Message& m) at System.Windows.Forms.UserControl.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(M essage& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Mes sage& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
InnerException:
Oscar Ferrrato
Hello Oscar,
Is the routine declared 'LOCAL'? If so, see if it makes any difference if it is not.
Are you using FP SDK 5.10?
Ingela Brorsson
ABB Robotics, Sweden0
