Install RAB
            I have installed VS2005 Standard on my PC.
I installed RAB, but when I go to new project... there is no Flexpendant project to Start!
Any ideas what the problem is??
Thanks in advance
Adolf
            Hi I had the same problem with the italian release of VisualStudio 2005, I just removed it and installed the English release. Regards Gianluigi 0
            RAB has only been tested with the English version of Visual Studio, so if you are running Visual Studio in any other language I recommend that you switch to the English version so that you are running in the tested/supported environment. If you still want the project to appear in Visual Studio of another language you need to manually copy the projects to the correct language folder
 For C# copy from:
 *ProjectTemplatesCSharpSmartDeviceFlexPendant1033
 For VB copy from:
 *ProjectTemplatesVisualBasicSmartDeviceFlexPendant1033
 Where * is read from the registry in (VS2005)
 HKEY_LOCAL_MACHINESOFTWAREMicrosoftVisualStudio8.0Insta llDirI think that German for instance is 1031... Then using the VS command prompt you can use "devenv /installvstemplates" commands to make VS read them at start up. John
 Developer Center0
- 363 IRC5
- 80 OmniCore
- 853 RAPID Programming
- 31 AppStudio
