Application Error
When I am attempting to open a new system in RS, I am able to save to a file path and select my robot, etc. However before the controller begins to initiate, I receive an error that says:
An application error has occurred and a support log will be created.
Information about the problem will be written to: c:...
However, this file path does not exist and immediately afterward RS crashes. Not sure what is wrong or how to fix, any thoughts? Thanks.
Michael VanHout
Michael VanHout
I suggest that you try Direct3D instead of OpenGL as render.
You change that in menu toolsOptions and then GraphicsRenderer.Per Svensson
Consat Engineering0 -
seems to have fixed the problem, thank you!
- 398 UpFeed
- 13 RobotApps
- 299 PowerPacs
- 405 RobotStudio S4
- 327 IRC5
- 65 OmniCore
- 821 RAPID Programming
- 8 AppStudio
- 3 RobotStudio AR Viewer
- 105 Collaborative Robots
