Application Error
When I am attempting to open a new system in RS, I am able to save to a file path and select my robot, etc. However before the controller begins to initiate, I receive an error that says:
An application error has occurred and a support log will be created.
Information about the problem will be written to: c:...
However, this file path does not exist and immediately afterward RS crashes. Not sure what is wrong or how to fix, any thoughts? Thanks.
Michael VanHout
Michael VanHout
I suggest that you try Direct3D instead of OpenGL as render.
You change that in menu toolsOptions and then GraphicsRenderer.Per Svensson
Consat Engineering0 -
seems to have fixed the problem, thank you!
