How to Drag and Drop?
I program a station with a custom tool, that should drag an object, move it to another position and drop it.
The question is how I can configure the tool to be turned on and off.
  • Hi,
    You need to set up events in the "Event Manager" to attach/detach objects.
    Take a look in the RS help, chapter "How to Work with the Event Table".
    Anders S2008-3-10 16:8:47
    ABB Robotics
  • Thank you very much for the hint, got it working.
