Paint Robots
Hi everyone!
Well, i'm trying to get a "sat" surface with the paint robots, specially the IRB5400-12 (or in RobotStudio IRB5400-02), because i've some problems with the video application of RobotStudio, and i would like to prove it with another 3D software.
I've looking for them on the Paint Area, in Inside ABB web, and i didn't find anything, only CAD modelsimage. Do you know where can i find them?
Thank you for your time!
BR
Jordi
I don't know what to say..
  • Hi Jordi,
    A somewhat similar topic can be found on the link below:
    http://forums.robotstudio.com/forum_posts.asp?TID=206&PN=1
    But to answer your question, the answer is that they (pretty sure) can't be found. The *.sat files of the robots are not included in the library, nor can the downloadable CAD models be attached/inserted/linked to the library models.
    But may i ask what kind of difficulties you encounter when using the video capture option? Are some entities/surfaces "disappearing" while the robot moves, or when the view changes? If that's the case you might want to toggle "Backface culling". You can find it under: tools>options>graphics
    Good luck!
    <@Logan&gt; I spent a minute looking at my own code by accident.
    <Beeth> And your point is?
    <@Logan&gt; I was thinking "What the hell is this guy doing?"
