snap trouble
I can not snap to any positioner I load into my systems. When I chose "surface" for a selection level and drag the mouse/cursor over the positioner, no surfaces light up. Robots and other imported library and geometry work fine. Can anyone help?<?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
The "geometry" of all these libraries have been removed in order to keep the file size as small as possible. This is why you can not click surfaces etc on the positioner models.
Anders Jahnberg, ABB Robotics
Anders Jahnberg
If I can't snap to any features on the positioner, how do I verify (measure) that it is positioned correctly in my system relative to the robot?<?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Also having similiar problems with the ABB supplied pedestal library.
Firstly why does the pedistal not line up with the robot by default.
Second how can i position it when you cannot measure or snap to anything on it?
- 5.4K RobotStudio
- 382 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 281 IRC5
- 48 OmniCore
- 3 RobotStudio AR Viewer
- 740 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
