error while loading programs to robot [WebWare SDK]
We are loading programs with SDK 3.2 activex to virtual robot ok, but when we trying to load it to real robot trough ethernet way i am getting next error: 40304
Could you please provide us with the source code for this program.
From the description above, it seems to me that you are referencing a path in your robot program ("c:vb....") which might be valid on the Virtual Controller, but not on the Robot Controller. Can you verify that this is not the case.
______________________________
Anders Dannberg
ABB Automation Technologies
Support Engineer0 -
Hi Anders,
Sorry, the first post error message is while i am triying to recibe the program.
To load a program my program line is in vb
status = robotHelper.S4ProgramLoad(0, Fichero, 3, resultid)
where fichero is the file location (local) C:VBORNI_ROBOTCARTER_5.prg
the error message is (sorry in French)
Temps:1029 12:03.2 Raison:T?che MAIN: Erreur E/S ! (nom du fichier: C:VBORNI_ROBOTCARTER_5.prg) V?rifier:Un des pb suivants: Erreur acc?s: Prot?g? en ?criture Fichier inexis tant Plus de place sur support MAIN C:VBORNI_ROBOTCARTER_5.prg
More details:
I am writing and reading any variables without problems to real robot
We are triying to load directly from local pc hd to robot main memory (MAIN). Can be that we need to send the file first to robot filesystem and then load to main (local to the robot ?)
Many thanks
Hello Olatz,
The S4ProgramLoad method will load programs only from the physical robot controller (RC). Local paths from the computer you are executing the SDK application from are not valid. If you load the program into the RC, you will be able to load the program using S4ProgramLoad.
To copy files from the PC over to the RC, you can use the S4FileCopy method.
AndersD38295,7048032407
Anders Dannberg
Support Engineer0 -
Hi Guys
I'm Trying to load a program in the S4+ from my PC using the S4ProgramLoad, when I try to load it, simply nothing happens, not even an error message. I think it might be the way I've written the file path, since the robot is connected to the pc via ftp server, I just write PROGRAM.prg...
Another thing, does the robot have to be in full auto mode to be able to load programs from the PC using the S4ProgramLoad method?
Thanks,
Ricardo Mesa
University of Wollongong
Mechatronics Engineering0
