tooldata name
Once I load a tool library feature into my "cell", how can I change the name of the tooldata? e.g. I want to change a tool called "Binzel" to "tWeldgun"
  • Hi,
    You can rename the tooldata in the Elements browser when you have attached the tool to the robot.
    But you can't change the name in the tool library, so the next time you attach the tool, the original name will be used.
    If you want a tool library with another tooldata name, you have to create a new tool with help of "Create Tool".
    ABB Robotics
