Mechanical Cut User Guide
Can anyone tell me if there is a User Guide for Mechanical Cut (PDF Form), like the ARCWELD PowerPAC??
I have search a number of sources but with no success.
Thanks in advance.
Andy B
  • Hi,
    A *.chm-file is included in the Mechanical Cut PowerPac. It's installed automaticaly. Although this might not be a PDF-file or a printed manual, it is basicaly the same. You can compare it with the *.chm-file which comes with RobotStudio itself. When you compare that file with the manual of RobotStudio, you'll find that they both contain the same information.
    The *.chm-file for Mechanical Cut can be found here:
    ...Program FilesABB RoboticsAddinsMechanical CutMechCut.chm
    Or you can download it from here:
    MechCut.zip
    Good Luck Wink
    <@Logan&gt; I spent a minute looking at my own code by accident.
    <Beeth> And your point is?
    <@Logan&gt; I was thinking "What the hell is this guy doing?"
