Add-ins in 2008
hi
I have a add-ind made for RS5.
I have tryed to import it to rs2008 but i cant se it active any where.
what is the problem? :)
Kent Zibrandtsen
Dept manager robot welding
Kez@hardi-international.com
  • Hi Kent,
    If you put the dll in BinAddins it should be visible in the Add-in tab. Is there any error message in the output window?
    regards,
    Johannes
    Johannes Weiman
    ABB Robotics
