option error in RS
Klaus
I have a system with Socket messaging but cant use socket in my rapid code. It says tha socket option is missing. Se screendump
Best regards Klaus
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
Klaus Soenderhegn
www.cadalysator.dk
Hi Klaus,
I failed to reproduce the problem using a basic system with only the Socket option. I used the code example of the Socket manual.
Please get in touch with your local ABB contact that will help you and also forward your issue to your technical support in Gothenburg if needed. This is the recommend way. Alternatively, you can also upload the information required here and we will try to help you. (Pack & Go).
Hi Henrik.
I made a new system and it now works.
i got the problem when i add the optionto an existing system.
Best regards klaus
Best Regards
Klaus Soenderhegn
www.cadalysator.dk0
- 5.4K RobotStudio
- 382 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 281 IRC5
- 48 OmniCore
- 3 RobotStudio AR Viewer
- 740 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
