Virtual Arc Problems [ArcWelding PowerPac]
I have been trying to test out virtual arc and have been running into problems with it. Whenever I try to do an analysis it gives me the following errors:
1) mllapack.dll procedure is missing
2) dgbtrf procedure is missing
3) predict_weld.exe failed to execute
The analysis just stops and freezes virtual arc.
Has anyone else had these problems?
-Ben
Hi Ben,
Do you have a version of MATLAB or MATLAB Runtime Engine previously installed?
Henrik Berlin2008-5-26 13:43:27Henrik Berlin
Hi Henrik,
No, MATLAB has never been installed on this system.
Ben
Please check if you find the file mllapack.dll in the folder
C:Program FilesMATLABMATLAB Component Runtimev76inwin32
Kind regards,
Henrik,
mllapack.dll is in the folder you specified.
Thanks,
Ben
OK, please check that the path above is added to the PATH system environment variable, see attached picture
Hi, i built an aplication in .NET and Matlab, obvious I have matlab in my computer but mi DLL is'nt registred, you know why?
thank u
