connecting other device to robot
hi, i have some question (..again..!image)
  1. i use the screw(with rotary) and a sensor. robot will move if it receive the trigger from the rotary and the sensor. so, how i connect them?
  2. can the controller of the robot handle all of my mechanism?(sensor activation, processing the pulse from rotary, and so on --> like PLC)
many thanks for your helps.
indah carmila
  • is there any relation with using the instruction template?
    indah carmila
