s4/s4c install system via serial port ?
irobot
if possible , how to?
normally, s4/s4c(M94/M96/M97) install system via floppy drive, but slowly and floppy disk broken after several times .
thanks!
thanks!
Hi!
It is not possible to load systems via serial port.
However, for S4C there is an option for an extra ethernet card with which it is possible to install systems.
Best Regards
Stefan Westberg
i wonder is there any other method to install the OS without floppy
