Autosave
Autosave is the best thing in RS soo you don't loos to much work when it chrashes....but can it also contain backup of the controller?.
3 times my RS has chrased to day and each time i loos rapid code because autosave dont make a backup.
Where is the rapid code placed in the VC.
Can it be restored after chras? My VC is still runing can i get it from there?
PLZ !!!image
BEst regards klaus
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
  • Hi Klaus,
    Just try opening the station again. If the VC is still running, RS should automatically connect to it rather than start a new instance. If you open the Rapid editor your code should still be there.
    regards,
    Johannes
    Johannes Weiman
    ABB Robotics
