error: No program loaded
hello, dear colleague:
would you please help to handle this kind of error? thanksimageue:
  • Hi
    Have you set up your main i the menu simulation --> Setup image
    Regards
    Knud Erik Lindberg
    Danrobotics
  • you mean, click the  Entry point   , choose Main,  then chose a path to the main sequence box?
    then yes
  • No from the Layout mode : simulation --> Setup image
    Regards
    Knud Erik Lindberg
    Danrobotics
  • yes??i have done that, doesn't help.
    and each time I want to simulate, I need to use F5 to go to the virtual controller interface. change the controller to automatic model and click PP to main  motor on, and at last close the virtual controller window.  then I click the simulation button, it works. but I don't konw why.
  • If you go to Program tab and browse to rutine, is there a main rutine in there, and what is in it.
    Regards
    Knud Erik Lindberg
    Danrobotics
