error: No program loaded
hello, dear colleague:
would you please help to handle this kind of error? thanksue:
Have you set up your main i the menu simulation --> Setup
Regards
Knud Erik Lindberg
Jorgensen Engineering0 -
you mean, click the Entry point , choose Main, then chose a path to the main sequence box?
then yes
No from the Layout mode : simulation --> SetupRegards
Knud Erik Lindberg
yes??i have done that, doesn't help.
and each time I want to simulate, I need to use F5 to go to the virtual controller interface. change the controller to automatic model and click PP to main motor on, and at last close the virtual controller window. then I click the simulation button, it works. but I don't konw why.
If you go to Program tab and browse to rutine, is there a main rutine in there, and what is in it.
Regards
Knud Erik Lindberg
- 5.4K RobotStudio
- 382 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 281 IRC5
- 48 OmniCore
- 3 RobotStudio AR Viewer
- 739 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
