help me out
hi friends
i m totally new to robot studio
i m using rs 5.09 from 2 days and i can make a path
but wen i play it change its direction..... it doesn't go througth the given path plz help me
my company need it
im regular user of PRO-E Wildfire 2
plz send some tutorails or notes which it will me in makeing it perfect
on my mail vibunews@gmail.com
thanks in adv......
There is a tutorial build in to robot studio have you run that ?
You shod upgrade to 5.10 it is included in your license.
Regards
Knud Erik Lindberg
Jorgensen Engineering0 -
hey thx Knud E Lindberg
for reply
last day i tried a lot then came to know that the configration
was wrong
and as u said tutorail...... it don't work here proper or its too less toturail to understd conscept.......
plz tell me
and i came with another prob here
hw can i move or rotate the object as per my robotarm
hi every one thats "Vj"0 -
hi if you right click on one of your external axes you will have to choose mechanism joint jog.
you can then move the slider back and forth, feks on a track, robot or what ever.
is this what you meen?
Kent Zibrandtsen
Dept manager robot welding
Kez@hardi-international.com0 -
hey thanks buddy......
not mech joints jog
if i'm keep my job on positioner then how can i move it
revole as shown in demo
plz.....
today i mail some question to ABB robotic but they did't replyed yet
do u know any valid email id where i can send it
so i can solve over there only
as i can't take out anything from company......
so give me an email id plz.........
thanking u
Just create a workobject and attach that to your positioner.
The create your targets in that wobj and they will follow when yopu move your positioner around. Also if you want to do corrdinated motion on a positioner you need to do it this way and define that the positioner moves the wobj.Hope this was the answer to your question
Per Svensson
Consat Engineering0 -
hiiiii friends.....
thanks
for replying my problem
as it was very imp
i hve send query to ABB 4 to 5 times but did't they replyed yet
Thanks to forum and the memnber also
i have bought some question which we hve send it to ABB
plz ...... my friends do.... reply on this
sorry its to many but
problem is ...... big problem ..........
sorry again friends
1- how to vary the speed of the robot as per our standard welding speed ?
2- Gv us d complete information abt VIRTUAL FLEX PENDANT as how fast we can use it
3- how to set program pionter, entry point for the task
4- how to simulate robot & positioner simultaneously (synchronization)
some error where i stuck in middle of the program
a) the task T_ROB1 has syntax errors in its RAPID program
b) synchronization to VC failed? what should i do...?????
c)program pointernot available....????
d) could not set program pointer to entrypoint for task T_ROB1
f) the program could not be started
plz tell how to over come like this errors
hey friend s
tell me frankly
should i must stick on RS
or leave it aside
bcoz it goiung tough day by day
and my company need results from me
and i don't have enough knowlegde on this
they only hv s/w no any manual to read it go through it......
plz help me out
if i must stick on it wat should i do for bettter results
thanks for reply
I can see that you have many questions and ma by a training in robotstudio will be good for you. If You go i to :
www.abb.com/robotics and send a mail to Arvind Vasu in India, he can inform you of the nearest robotstudio training center.
Regards
Knud Erik Lindberg
- 337 IRC5
- 67 OmniCore
- 831 RAPID Programming
- 14 AppStudio
