Full screen Usability
I'd like very much the full screen view, but as it is now , it is not so useful.
What about to add a 4 arrows in middle of the 4 borders and when the mouse is moved over on of the arrows, the standard rs elements will appears:
For example if i move the mouse on the top arrow, the ribbon slide down, i can click on the desired button, then when i move the mouse away, it automatically disappers.
See pic1 and pic2
(yuo can take as reference the Adobe Lightroom sw)
BR
Oscar
Oscar Ferrrato
BR
Oscar Ferrrato0 -
Hi Oscar,
The full screen feature is primarily intended for multi-monitor environments. If you have two monitors, the fullscreen window is opened on on the secondary monitor and you can still access the ribbon etc (as well as a second document window, e.g. Rapid editor) on the primary monitor.
Your suggestion is definitely a good idea for a single monitor though!
Note that you can achieve something similar already by minimizing the ribbon and setting the tool windows to auto-hide:
regards,
Johannes
Johannes Weiman
I've another problem with full screen RAPID editor...when I accept the modifications, for example using check button or "step over" button RobotStudio crash!
The software is blocked and only solution is shutting down the process...
Have you the same problem?
- 303 PowerPacs
- 353 IRC5
- 849 RAPID Programming
- 24 AppStudio
