SyncData gets error
chen
I am trying to use the following command to syncronize a work object from a macro to the VC:
station.ActiveTask.SyncData("Module1/workObjBattery", SyncDirection.ToController, new System.Collections.Generic.List<SyncLogMessage>());
However, I always get this error:
The given key was not present in the dictionary.
Apparently the name Module1/workObjBattery is correct. What could have gone wrong here?
Thanks,
Sam
chen2008-7-3 21:1:330
Looks like this only works if you create a real addin and not thru VSTA.Per Svensson
Consat Engineering0
- 346 IRC5
- 73 OmniCore
- 844 RAPID Programming
- 20 AppStudio
- 108 Collaborative Robots
