Using Instruction "UIMessageBox"....
Use Systempack 5.10.1042 (Latest RAB)
I have a problem when I use the instruction "UIMessageBox" in combination with a active RAB application. When the "UIMessageBox" is active in a Multitask the operatorbutton has suppose to start blinking yellow, a indication for a operator to press OK from the UIMessageBox. The blinking is not starting when the RAB screen is active. When I jump for example to the production screen the operator next to the "ABB" button starts blinking!
Do someone has a soluition or do I need to wait for a new system pack?
Best Regards,
Edwin
Do you know for certain that this behavior has changed from previous versions of RW?Russell Drown0
Sorry for the late reaction.
The problem sometimes occured by other customers of ours but we did not know what it was. I am sure that is was the same in earlier versions. It is the same as in other versions but it is not ok.
Edwin,
Hi Edwin,
I was curious about this issue. When you say "an active RAB application", do you mean a FlexPendant application that has focus on the screen when the UIMessageBox posts?
/Bryan
Bryan Johnson
bryan.johnson@wolfrobotics.com
Wolf Robotics
4600 Innovation Dr.
Fort Collins, CO 80525
USA0 -
Hello Brian,
Yes that is correct, when for example the "Program Data" screen has acces it works ok!
Greetings,
Edwin
- 339 IRC5
- 67 OmniCore
- 832 RAPID Programming
- 14 AppStudio
