Test workobject!
TRiXTeR
Hi!!
Is there any way to test a wobj? Run it like a program to see exactly where it is?
//Fredrik
//Fredrik
Create a target with a zero position and use that target togheter with your workobject in a motion instruction and just run that motion instruction and the tcp(you use) will end up in the workobject position.Per Svensson
Consat Engineering0
- 365 IRC5
- 84 OmniCore
