why do we need triggdata?
First of all, my english is not my best so I don't know if I've understood you correctly...
If you want to wait the movement to be finished just before making anything else...
You can use:
WaitTime 0;
As far as I know any attempt to modify a signal (DI, DO...) will also stop it.
Also you can place a FINE at the movement just to make it to finish the movement before making something else...
But anyway, I've not understood the point with triggdata... As I understand it it is used precisely to be able to activate an output just at a certain distance from a specified point... something that in the other hand would be impossible (I don't know if placing two movements to the same place and the first one with a bigger zone would work (I suppose that) but you'll have more control with triggdata)...
Hope this helps...
Use a stop point (zone = fine) if you don't want the following instructions to be executed before the robot has finished motion.
ABB0
- 365 IRC5
- 38 AppStudio
