How to mask a num value?
I have a number of 104 (example, changes depeding on what the number I get from the PLC is). I would like to read the two last digits of 104 (04) and read that into a new num, is this possible in RAPID? Shearched but can't find anything regarding that.
Alexander K
AlexK2008-8-6 10:56:13Alexander Källberg
Hi Alexander,
Try this:
m = your original integer
n = the two last digits
n = m - Trunc(m / 100) * 100
Example:
m = 1234
m / 100 = 1234 / 100 = 12.34
Trunc(m / 100) = Trunc(12.34) = 12
Trunc(m / 100) * 100 = 12 * 100 = 1200
n = m - Trunc(m / 100) * 100 = 1234 - 1200 = 34
Disclaimer: This algorithm was not tested in RAPID and needs to be validated before put into production.
Henrik Berlin2008-8-6 16:49:40Henrik Berlin
Or something like this
Per Svensson
Consat Engineering0 -
Thank you very much, need to put me into the above examples, I'm not a math genius, but I don't think it will be a problem, else I will bother the two of you again
Alexander K
Best regards
Alexander Källberg0
- 364 IRC5
- 82 OmniCore
