Instruction Template Manager?
DanS
Where do I open instruction template manager in 2008?
Thanks,
DanS
At the home tab you will find a tiny!!! arrow in the lower right corner of the path programming group.Per Svensson
Consat Engineering0 -
You can also open it from the menu of the status bar that appears when you selected the currently active instruction template.
ABB0
- 303 PowerPacs
- 353 IRC5
- 849 RAPID Programming
- 24 AppStudio
