SDK Error Constants [WebWare SDK]
Hi,can you please explain your problem again, I don't fully understand what you want to accomplish?
If you want them manually then you have them in the [Installation and Setup Guide] chapter 4.
If you programmatically have the number but want the description then you can use the Helper.ErrorMessage(errorcode) function
Here is a short example:
intRetVal = Helper1.S4ProgramVariableRead(Text2.Text, 0, myArray)
If intRetVal <> 0 Then
Label1.Caption = Helper1.ErrorMessage(intRetVal)
Exit Sub
End If
It would also be possible to do something like this:
Label1.Caption = Helper1.ErrorMessage(Helper1.S4ProgramVariableRead(Text2.Tex t, 0, myArray))
That's what I am doing. What I am looking for are constants for the actual error codes. What I am forced to do at present is to create a constant for each error# (rather than use "-3113" atl the time). Example...
Const SDK_ERR_DIR_NOT_EXIST = -3113
sdk_status = ilinkRobotHelper.S4Dir(ilinkRobotHelper.DevList(0), edtDeviceDir.Text, SDK_UNIMPLEMENTED_ARG, 3, lResultID)
If ( SDK_ERR_DIR_NOT_EXIST = sdk_status) Thenmsgbox( ilinkRobotHelper.ErrorMessage(sdk_status) )
end if
thanks,
Ok, now I'm following.
I don't think there is such a list of error number constants. Sorry.
- 338 IRC5
- 67 OmniCore
- 832 RAPID Programming
- 14 AppStudio
