SETGO Issues
Hello, I have a question about how to handle Group Output / Inputs. Below is a Main PROC that I am running in the actual robot. I have loaded the EIO file that contains the GO into Robot Studio but I am setting a (Task MAIN: Reference to unknown entire data gooption). Is there a way of running this in studio, because right now I am having to REM out the SETGO and WaitUntil lines. Thanks in Advance. Bob
PROC main()
ConfJOff;
ConfLOff;
SetGO goOption,0;
WaitUntil GInput(giOption) = 1;
Proc_1;
SetGO goOption,1;
WaitUntil GInput(giOption) = 2;
Proc_2;
SetGO goOption,2;
WaitUntil GInput(giOption) = 3;
Proc_3;
SetGO goOption,3;
WaitUntil GInput(giOption) = 4;
Proc_4;
SetGO goOption,10;
MoveL phomepos,v500,fine,tUserTool0;
Hello Bob,
Could post also the EIO that you are using, and a list of the options that you have in your VC?
Regards,
Jan-Jaap0 -
Hi Bob
If you open the teachpendant in RS and go to the IO view, can you then see the group signals goOption and giOption?
Per Svensson
Company Specialist
Hello Jan-Jaap and Per,
Attached is a copy of one of the robots I am have in RS.
Jan-Jaap --- What exactly fo you mean by options in the VC?
Per --- As far as the IO view, I am showing absolutely nothing for IO
I am attaching an Excel file.zip with snapshots of the errors that are appearing on the TPU.
Thank you for looking into this. If there is anything else that I can send you to see whats going on, please let me know
SetGO_Errors_ABB_SoftWare_Support.zip
Hello Bob,
Your EIO file is not complete: there are some unit types missing. If you start your VC from the windows teach pendant you will see some errors appear:
unspecified unit type AcaVsio
unspecified unit type AmaVsio
unspecified unit type DPIO
You will have to specify them in your EIO file (or in system parameters -> IO -> unit types.
Good luck,
Regards,
Jan-Jaap0
