OPC server
Klaus
I have found OPC server on the Robotware CD and indstalled it.
The Dok refers to a client. Where can i get that.
Do i need a license to run it?
Best regards Klaus
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
Klaus Soenderhegn
www.cadalysator.dk
A client is a software that can read from OPC Server(which is supplied by the manufacture)
Some example of clients (there is a lot of them)
- Intouch
- A software written by your self.
A good place to start is http://www.opcfoundation.org/Per Svensson
Consat Engineering0 -
A free demo client with both Data Access and Alarm and Event funtionality can be obtained at:
http://www.softing.com/home/en/industrial-automation/downloa ds/drivers-demos.php?navanchor=3010451
registration is required. Also, KepWare has a nice, easy to use DA only client that can be downloaded as part of their KepServer packge.
Russell Drown0
