MTC Library
marcus
I'm needing MTC_500 RobotStudio stantard Library.
Do you have that? Where could I find?
Inside http://www.abb.com is possible find just library to the old robotstudio (S4).
Please help me asap!
Marcus Daniel
ABB Robotics
mobile: +55 11 8586-4960
ABB Robotics
you can import old RS4 libraries into RS5 just select file format rlbPer Svensson
Consat Engineering0 -
I already tried that Per.
But nothing happened and the RS show Import Failed message.
Did you imported the MTC library with succees? If yes, could you sabe the library like RSLIB and send me?
Marcus Daniel
ABB Robotics
mobile: +55 11 8586-49600 -
Here you go
Had no problem importing (have you tried change between Direct3D and OpenGL as render)Per Svensson
Consat Engineering0
- 303 PowerPacs
- 353 IRC5
- 849 RAPID Programming
- 24 AppStudio
