MTC Library
I'm needing MTC_500 RobotStudio stantard Library.
Do you have that? Where could I find?
Inside http://www.abb.com is possible find just library to the old robotstudio (S4).
Please help me asap!
Marcus Daniel
ABB Robotics
mobile: +55 11 8586-4960
ABB Robotics
you can import old RS4 libraries into RS5 just select file format rlbPer Svensson
Consat Engineering0 -
I already tried that Per.
But nothing happened and the RS show Import Failed message.
Did you imported the MTC library with succees? If yes, could you sabe the library like RSLIB and send me?
Marcus Daniel
ABB Robotics
mobile: +55 11 8586-49600 -
Here you go
Had no problem importing (have you tried change between Direct3D and OpenGL as render)Per Svensson
Consat Engineering0
- 5.4K RobotStudio
- 381 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 281 IRC5
- 47 OmniCore
- 3 RobotStudio AR Viewer
- 739 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
