MTC Library
I'm needing MTC_500 RobotStudio stantard Library.
Do you have that? Where could I find?
Inside http://www.abb.com is possible find just library to the old robotstudio (S4).
Please help me asap!
Marcus Daniel
ABB Robotics
mobile: +55 11 8586-4960
  • you can import old RS4 libraries into RS5 just select file format rlb
    Per Svensson
    Consat Engineering
    I already tried that Per.
    But nothing happened and the RS show Import Failed message.
    Did you imported the MTC library with succees? If yes, could you sabe the library like RSLIB and send me?
    Marcus Daniel
    ABB Robotics
  • Here you go
    Had no problem importing (have you tried change between Direct3D and OpenGL as render)
    2008-09-12_063801_MTC500.zip
    Per Svensson
    Consat Engineering
