Flexpendant viewer to RSO
Klaus
On RW cd with my new robots there was Flexpendant viewer Addin to RSO. I have installed it but can't open it. I have a costumer that wants to use it to.
He run RSO 5.09.2037. I tried to upgrade to the RSO that somes with RS 5.10 but stil don't work.
What can be wrong?
Best regards Klaus
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
Klaus Soenderhegn
www.cadalysator.dk
Does he have an RSO license installed? It may be one of the features that requires a license.
What do you mean it doesn't work? Is the Open menu enabled when a controller is selected in the RobotView, but no picture or an error message instead of the screenshot is displayed when you click open?
Russell Drown0 -
You need the PC Interface option on the controller to use the FlexPendant ViewerPer Svensson
Consat Engineering0 -
Hi Per and Russ.
It was license that missed
Thanks Klaus
Best Regards
Klaus Soenderhegn
www.cadalysator.dk0
- 5.4K RobotStudio
- 382 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 281 IRC5
- 48 OmniCore
- 3 RobotStudio AR Viewer
- 739 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
