Installing RS5.11
sturner
When Installing 5.11, should I expect any problems with existing stations and virtual controllers? <?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
I.E. uninstalling 5.10 first
Will I loose information?
Does it use the same library folders / media pool?
Will installing overwrite existing files?
Is licensing done in the same way?
Many thanks
Have you read the release noteInstallation
RobotStudio 5.11 will automatically upgrade any existing installation of RobotStudio
5.10 or 2008. Any previous installation of RobotStudio Online will remain untouched.How to migrate from RobotStudio 5.10 to RobotStudio 5.11
All your existing stations, libraries, geometries, controller systems, and add-ins can be
directly reused in RobotStudio 5.11. RobotStudio 5.11 is compatible with previous
releases of RobotWare (see also section Known Limitations).
Note: Stations or libraries created in RobotStudio 5.11 cannot be used in RobotStudio
5.10.Regards
Knud Erik Lindberg
Jorgensen Engineering0 -
Hi,The licensing system of RS 5.11 is replaced. The reason is to enhance user experience.Henrik Berlin
ABB0
- 303 PowerPacs
- 353 IRC5
- 849 RAPID Programming
- 24 AppStudio
