API sync to station
Saibel
Hi!
I try to write a procedure to sync a Rapid proc to station:
Set pro = pros.Item("PROC1")
pro.Refresh
An empty path "PROC1" exists.
I get the following message:
"Synchronization of element PROC1 succeeded."
But in fact it looks like RS syncronizes station to virtual controller instead of the procedure to station. Anyway, I don't get some robtargets into the "PROC1" path.
Sergej Saibel
Sergej Saibel
Here is a simple example how to sync a module from VC to RS.
Module name in VC ="myModule"
Procedurename in VC="Path1"Sub SyncToStation()
Dim SyncToModule As ABBS4Module
Set SyncToModule = ActiveStation.ActiveMechanism.Controller.Modules("myModule")ActiveStation.Paths.Insert SyncToModule.Procedures("Path1")
End Sub
Per Svensson
Company Specialist
Thank you very much, I will try this.
Sergej Saibel0
