Flexpendant Application Install
bhaughey
Hello all,
Simple question... How do I actually install and run a RAB designed application in a Flexpendant. I've built the project and copied the '.dll' and 'gtpu.dll' files into the controller itself under the Home directory (I've gathered that much from the user guide.pdf). How do I now run this application?
Thanks in advance for your help,
Ben
Ben
Never mind.
I think the fact that I don't have the "FlexPendant Interface" Option enabled in the controller has something to do with it
Will try that first.0 -
You are absolutely right that You should have a system with Flexpendant Interface option and also after putting the ".dll" into HOME folder of the system , you must restart the FlexPenadantSunil Sabut
India Corporate Research
ABB - India0
