defining a stationary TCP
Would like to simulate a fettling application on robot studio. A?Component is held with a gripper on the robot. A?Tool is stationed on a pedestal. I need to define TCP stationary on the tool. Can anybody explain the step by step procedure please.
rgds
ignorance is bliss
No answersA?
A? ignorance is bliss0 -
Check the Technical reference manual - Rapid instructions, functions, and data types.
Look under tool data.
Hi again,The Operating manual - IRC5 with flexpendant has a step by step guide (using the flexpendant) under programing and testing then the tools chapter.0
Thank you Graeme. I will check up and let you know the resultsA?
ignorance is bliss0
- 303 PowerPacs
- 353 IRC5
- 849 RAPID Programming
- 24 AppStudio
