Problem with Robotsudio 5.11
Geoff
I have just installed Robot Studio 5.11 and when I open a station I get an error "Release directory C:PROGRAM FILESABBINDUSTRIALITMEDIAPOOLROBOTWARE_5.11.0160 is missing or corrupt, and cannot be used to open a VC."
I have checked the directory and ROBOTWARE_5.10.0149 is not there. However there is a file C:PROGRAM FILESABB INDUSTRIALITMEDIAPOOLROBOTWARE_5.11.0160
<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
It seems that the software is looking for the wrong file. Can anyone tell me how to fix this?
ThanksGeoff2008-11-08 05:32:46
Hi,I recommend that you reinstall RobotWare 5.11.0160.Best regards,
Are you using a 64-bit operating system (XP 64 or Vista 64)?
Johannes Weiman
Hi,RobotStudio can be seen as a client of the VC. The VC is running a RobotWare system. Both RobotWare and RobotStudio must be installed to run a VC.Assuming RS asks for "RobotWare 5.10_0149", this means that you are trying to start a VC running a RobotWare system of this version. To run that you need to install that version. That particular version was distributed with RobotStudio 2008. RobotStudio is backwards compatible with respect to RobotWare which means that RobotStudio 5.11 can be used with previous versions of RobotWare (with some limitations, see Release Notes).Henrik Berlin
I have the same problem:
But the directory is there and all the files too...
I'mA?usingA?WinA?XP 64-bit.A?IsA?theA?aA?problemA?byA?usingA?64-bitA?withA?RW5.11.0160?
- 304 PowerPacs
- 356 IRC5
- 75 OmniCore
- 850 RAPID Programming
- 26 AppStudio
