About "Michanism joint jog" Window
  Can I let the "Michanism joint jog" Window always show. As usual ,I first open "Michanism joint jog"Window, then , if i open another one ,"Michanism liner jog"Window ,for example, the "Michanism joint jog"Window will disappear, but I want to let the "Michanism joint jog"Window show at same time ,that is important to me ,because i want to supervise the dgree of each axis when i  liner jog or rotate!Is there any way to do so?Thank you!
