Create points at modelling
It is possible to create points at modelling??
thx
If you mean create targets just open the create target dialog and then switch to modeling.You can also tear off the create target dialog.Per Svensson
Consat Engineering0 -
And if you mean CAD-type point entities, no it's not possible.
regards,
Johannes
Johannes Weiman
ABB Robotics0
- 5.4K RobotStudio
- 382 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 281 IRC5
- 47 OmniCore
- 3 RobotStudio AR Viewer
- 739 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
