Cartesian Soft Servo in multi-direction
sxc86
I am playing around the CSS in 5.11.0016 (ABB Internal).
I want to activate CSS in ALL the Cartesian direction (i.e. X, Y and Z).
But CSSAct only accepts ONE direction.
Has anybody try this with success ? If so could you teach me how ?
Thanks ! - sxc86
Thanks ! - sxc86
According to some tests done with ABB, you can only have one direction of freedom. I do not know exactly what kind of application you have, but see CSS as a spring.0
Hello,SoftMove can only be used in one axis. from the manual
Main parameters for basic behaviour
SoftMove can be used in one of the Cartesian directions X, Y, or Z and this direction can be chosen to be in relation to either the tool or the work object. The basic behaviour of the softness is mainly controlled by two parameters - stiffness and damping.0 -
I confirm. I used the option in one plant just installed and I can confirm what have been said.Fabio
C.I.A. Automation and Robotics
www.ciaautomazione.it0 -
hi..I want to know more about soft servo for cartesian. I already use the rw5.10 for my robot. if i want to use soft servo for cartesian, am i need to create new system using rs 5.11? or can i use the installed system (rw 5.10)?I need it in order to make the movement smoother, because I need to move some fragile object using robot. is it enough to use the soft servo for cartesian only?thanks before.best regards,carmilaindah carmila0
HiCartesian soft move is an option you can bay for the robotRegards
Knud Erik Lindberg
Jorgensen Engineering0 -
CSS is only available from RW5.110
Correct me if I'm wrong but if I can use "relation to either the tool or the work object" then I could define any angle that I want? Then by redifing that wobj I could change the angle for the next targets and so on?John
Developer Center0 -
Hello carmila
, if softMove can't bring your good results for fragile object . you can try an other option: ForceControl, it's very smooth. Peter0 -
hi peter
thanks for your advice. is force control also can used in rw 5.10? or only in rw 5.11?
thank you.
best regards,
carmila
indah carmila0 -
Hello Carmila,Both SoftMove and FC Assembly are available as options in RW 5.10.01.If you are trying to move a fragile object try adjusting you acceleration and deceleration of your movements using the Rapid instructions AccSet or PathAccLim. These commands will allow you to soften the movements. These will add cycle time to the process.BRJim Proulx0
Hi Inda,Yes, if you redefine your workobject you can adjust the direction. Force control is the 'big brother' of CSS, also more expensive... Force control uses extra sensors which are directly connected into the control system of the robot. CSS is more or less a software solution.Hope this helps.0
hi all,thank you for the responses. I will explore and learn more about force control and css.thankss..
BRcarmilaindah carmila0 -
good luck, Carmila!Peter0
- 365 IRC5
- 84 OmniCore
