Axis scope of a program
I need some help.Sometimes I want to kown the six axises scope of a program(I konw in Robcad have this function), it is very helpful to decide the program is good or not, is the a addin to do so?Thank you!
Hi,Check the add-in available in the following thread:
By "axis scope", do you mean the range of values for each axis when running a program?
In that case the add-in that Henrik mentioned won't help, but it would be quite simple to write one that does...
regards, Johannes
Johannes Weiman
[QUOTE=Johannes Weiman]By "axis scope", do you mean the range of values for each axis when running a program?
regards, Johannes
[/QUOTE]Yes,Could please you help me....0 -
regards, Johannes
[/QUOTE]Yes....could please help me0
- 5.4K RobotStudio
- 382 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 281 IRC5
- 48 OmniCore
- 3 RobotStudio AR Viewer
- 739 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
