need help,please
dear all,
we have already programmed IRB 640 m2000 and sent it to our customer. There are some error, name error, and our customer directly use c-start. As result, the system and all program is gone. We don't have the backup system, because we never install the system (our senior said that the system is downloaded by ABB person in MAlaysia).A?
I read from the manual for RW 4.0 S4Cplus, that if the controller has no system, the things that I must do is to create new system, using robotware key, and then load program from backup ( we only have program backup, and not backup system).
But, the robotware key is also gone. so what should I do?
Here is the data for the robot:
IRB640 M2000
Robot Version IRB640
Power 8.3 KVa
Man Order 218146
Ref.No: RP301943001
Serial No: 64Z-20487
What should I do? I have already contact ABB in my country, and they said, they will contact Sweden for tracing the key, but until now, there is no response. Our customer complaining about it. I'm really confused. Can someone help us to solve this problem?
Can I borrow some key?Are there any way that I can do to create new system?
THank you very much
best regards,
Carmila
do you have a "program backup?"
If you have a file key.id in the backup I can help you read it so you can get the key.0 -
dear henrik,
A?
thank you for your response. but i also don't know what kind of backup that they have. it's already long ago, and i'm a new staff, so i don't know the backup, file, etc. But , finally, ABB Sweden can send us again the key.
. Fiew.. thanks....
thankkksss.........
indah carmila0 -
Dear henrik,
we have another kind of abb robot that lost the robotware key. but, we
still have the backup. can you help me to read the key? the backup is
in the attachment.
thank you so much
BR
carmila
webwiz/2005/BAK0730.zip
indah carmila0 -
I have send the key to your private mail box.Regards
Knud Erik Lindberg
Danrobotics0 -
HiThis is easy to do yourself if you have a backup and robinstall.
Just use the update function and use the browse mediapool and select the backup directory and it will display the system together with the key at the bottomPer Svensson
Consat Engineering0 -
Dear Knud,
Thanks for your help. I've read it.Thank you so much.
Dear Per,
Thanks for your advice. The RobInstall CD also lost. I can't find it. I've already ask to ABB Jakarta for send the copy for me. When the CD come, I will try your suggestion.
Thank you all
BR
carmila
indah carmila0
